Create single sign-on (SSO) user in OnGuard
These instructions are not meant to replace the knowledge of a trained LenelS2 system administrator. They are here to enable the basic setup of an authentication directory and SSO user so that the integration can connect to the OnGuard system.
Go to the Administration menu and select Users…
Add a new user, or modify a user from the list of internal system users.
On the General tab Access to this system is disabled should NOT be selected.
On the Directory Accounts tab click Link to associate the user to the directory user (or local account user) from the SSO directory created in this topic: Create single sign-on (SSO) directory in OnGuard.
In the Select Account dialog select the directory from the Directory list. Click Search and select a user in Accounts then click OK.
Once selected, the OnGuard user account is linked to the corresponding Directory account.
On the Internal Account tab, make sure that the User has internal account option is selected. Next, enter the account credentials.
On the Permission Groups tab assign the following permission groups:
System = System Admin
Cardholder = Cardholder Admin
Monitor = Monitor Admin
Reports = Full Access
Field/page = View/Edit All Fields
