Create single sign-on (SSO) directory in OnGuard
These instructions are not meant to replace the knowledge of a trained LenelS2 system administrator. They are here to enable the basic setup of an authentication directory and SSO user, so that the integration can connect to the OnGuard system.
  1. Using the OnGuard System Administration app, go to the Administration menu and select Directories.
For an OnGuard Enterprise system, create directories from the master server.
  1. Choose the directory type, either Windows Local Account or domain user account.
    For Windows Local Account support, the single sign-on account MUST be a Windows Local Account.
    For Domain User Account support, the single sign-on account MUST Allow manual single sign-on as shown below.
If you are creating a Directory of a type other than Windows Local Accounts (e.g. LDAP, Active Directory), verify the SSO user is a member of the Local Administrators group.
