Logging in (troubleshooting)
Error messages and warnings
You have tried to log in at a time when your user permissions do not allow you to log in. To resolve this issue:
Wait until you are permitted to log in. Contact your system administrator if in doubt about your user permissions.
You currently have no access permissions to any part of the XProtect Smart Client, and therefore you cannot log in. To resolve this issue:
Contact your system administrator, who will be able to change your access permissions if required.
This error message only appears in a very rare scenario, where a backed-up configuration from one XProtect VMS system is mistakenly used without any modification on another XProtect VMS system. This can cause different cameras to "fight" over the same identity, and that can in turn block your access to the XProtect VMS system. If you see such a message, contact your system administrator.
You have entered your own credentials in the Authorized by field. You cannot authorize yourself. To resolve this issue:
You must contact the person who has authorization permissions. This could be your supervisor or your system administrator. This person must enter his or her credentials to authorize your login.
You have tried to authorize a user but you do not have the user permissions to do so. To resolve this issue:
Ask your system administrator to check that you have the necessary permissions to authorize other users or ask someone else with sufficient user permissions to authorize the user.
It was not possible to connect to the XProtect VMS server at the specified server address. To resolve this issue:
Verify that you have entered the correct server address. The http:// or https:// prefix and port number are required as part of the server address (example: https://123.123.123.123:80, where :80 indicates the port number). Contact your system administrator if in doubt.
It was not possible to log in with the specified user name and/or password. To resolve this issue:
Verify that you have entered your user name correctly, then enter your password again to ensure it does not contain errors. User names and passwords are case sensitive. For example, there may be a difference between entering Amanda and amanda.
The maximum number of clients allowed to connect to the surveillance system server simultaneously has been reached. To resolve this issue:
Wait for a while before connecting again. If access to the surveillance system is urgent, contact your system administrator, who may be able to extend the number of simultaneously connected clients.
Occurs if you try to log in to a server that does not have a certificate installed. To resolve the issue, contact your system administrator, or click the Allow button to log in using HTTP, a network protocol that operates without the use of a certificate.
If your XProtect Smart Client is connected to a VMS or a federated site using the older security model (HTTP), a Not secure information message is shown to the left of the Global toolbar.
Occurs if your time-dependent user permissions no longer allow you to do something that you have previously been able to do. This is because, when connected to certain types of surveillance system (see Surveillance system differences), your user permissions may vary depending on time of day, day of week, etc. Therefore, you may well be able to perform the action again at a later stage.
Occurs if your current XProtect Smart Client session is about to end. When connected to certain types of surveillance system (see Surveillance system differences), your permissions to use the XProtect Smart Client may depend on time of day, day of week, etc.
When that is the case, you will typically see this message a number of minutes or seconds before your session will be closed; the exact number of minutes or seconds is defined on the surveillance system server.
Occurs if you have not used your XProtect Smart Client for a while (the exact time is defined on the surveillance system server), in which case your XProtect Smart Client session will be closed for security reasons.
When that is the case, this message will typically be presented a number of minutes or seconds before your session will be closed; the exact number of minutes/seconds is defined on the surveillance system server.
