Buttons
XProtect Smart Client has multiple buttons that allow you to perform different actions. The buttons are located in the in the upper-right corner.
The buttons available vary depending on the tab you are standing on. For example, Setup is not available on all tabs.
Button |
Description |
Time zone |
Set up time zone. |
Evidence lock list |
View evidence lock. |
User menu - Login information |
The status of your XProtect VMS servers that your XProtect Smart Client is connected to through Milestone Federated Architecture. |
Log out |
Log out of XProtect Smart Client. |
Toggle theme |
Switch the XProtect Smart Client theme to dark or light. |
Server jobs |
Depending on your user permissions to retrieve data from interconnected hardware devices or cameras that support edge storage, you can view the server jobs created for each data retrieval request for these devices. |
Settings |
Configure XProtect Smart Client settings and behavior, joysticks, keyboard shortcuts, language, and more. |
Help |
Access the help system, play online video tutorials, or view version number and plug-in information. |
Video tutorials |
Opens the Milestone Learning Portal. |
About |
Information about the latest XProtect Smart Client plug-ins and versions. |
Setup |
Enter setup mode. |
Toggle full screen mode ![]() |
Toggle between full screen and a smaller window that you can adjust to the size you want. |
Export |
Export video evidence. |
Evidence lock |
Create an evidence lock to prevent evidence from being deleted. |
Retrieve |
Retrieve recordings from interconnected hardware devices or cameras that support edge storage. |
Lift privacy masks |
Users with sufficient user permissions can temporarily lift privacy masks |
