Install the server certificate on a computer
Install the server certificate on all computers that will access the failover web console.
  1. Copy the serverCert.crt file from the primary computer to the computer that needs to access the failover web console.
  2. Right-click the server certificate and select Install Certificate.
  3. In the Certificate Import wizard, choose the Store Location:
    • For the primary and secondary computers, select Local Machine
    • For all other computers, select Current User
    Select Next to continue.
  4. Select Place all certificates in the following store and specify a folder.
  5. Select Browse, and then Trusted Root Certification Authorities.
  6. Select OK and Next.
  7. On the Completing the Certificate Import Wizard dialog, select Finish.
  8. If you receive a security warning that you are about to install a root certificate, select Yes to continue.
    If the import has succeeded, a confirmation dialogue box appears.
  9. Verify that the server certificate is listed in the center view of the Trusted Root Certification Authorities subtree.
