Identify the host name of a node
The failover web console represents the primary computer as node1 and the secondary computer as node2. To see the host name that corresponds to a node:
  1. On a computer that has access to the failover cluster, open a browser and specify the URL of the failover web console using this format: http://[computername.domainname]:9010 or https://[computername.domainname]:9453.
    The [computername.domainname] is the FQDN of the primary or the secondary computer.
    On the primary or the secondary computer, double-click the icon of the XProtect Management Server Failover web console on your desktop.
  2. To log in to the failover web console, you must authenticate with the user name admin and the password you set during the configuration of the failover cluster. If you do not remember your password, see Change the password for authentication.
  1. Select one of the nodes.
  2. Select the Information tab.
  3. In the Server information area, you can see the host name of the computer.
