Using the Select Certificate menu
From the server hosting the OnGuard XProtect Access Service right-click the service tray icon for the OnGuard XProtect Access Serviceand choose the Select Certificate...option.
This opens the Select Certificate dialog. Initially, the Use default self signed certificate option is selected.
The option is also available to choose any other certificate. Choose the Use certificate from the list below option to select any certificate from the local machine's personal certificate store.
If there are no certificates available in the list, please refer to Secure communications explained and read about creating compatible certificates.
The Certificate properties... button launches a properties menu for the chosen certificate.
