XProtect Access instance connection properties
The credentials and parameters required to connect the XProtect Access instance to the CCure 9000 system are detailed below:
Property Name |
Required Entry Details |
Name |
Custom name field |
Integration plug-in |
Displays the current version of the ACM MIP Plugin |
XProtect Access Service Host |
[ Hostname.Domain.TLD ] This field should contain the Fully Qualified Domain Name (FQDN) of the CCure 9000 server where the XProtect Access Service was installed. |
XProtect Access Service Port | 8443 is the default |
XProtect Access Service - SSL Certificate Validation | Enables SSL certificate validation between the CCure XProtect Access Service and the CCure XProtect Access MipPlugin. This option is required to use a third party certificate. Not enabled by default. |
Victor Web Service - Host |
Host name of the CCure 9000 server |
Victor Web Service - Port |
Victor Web Service - Use HTTPS |
HTTPS is required for secure connection to CCure 9000 by default |
Victor Web Service -SSL Certificate Validation | Enables SSL certificate validation between the CCure XProtect Access Service and victor web service when a third party certificate is being used. Not enabled by default. |
Victor Web Service - User |
[ Domain\Username ] for a user account with administrative privileges on the CCure 9000 server. |
Victor Web Service - Password |
Password for the user account selected for the “Username” field. |
Options – States polling interval (seconds) |
Default value is 900 seconds. Frequency of status updates retrieved for access control hardware devices. |
Options - [Legacy] Connection Profile | Used for backward compatibility with previous versions of the integration (after an upgrade). In most cases, this field must be empty. |
Options – Enable performance metrics (diagnostics) |
Not selected by default. Select this option to include performance statistic logging on event metadata. |
