Using DLNA certified device to view video streams
To start watching live video from your XProtect system on your public displays or TV, follow these steps:
- Make sure your device is DLNA certified and connected to the network with XProtect DLNA Server.
- Scan the network and connect to XProtect DLNA Server when it has been discovered.
A list of the different channels appears.
- Connect to the channel that you want to show video from.
- Verify that the selected channel shows video.
