Stream video from your device to your surveillance system
If your system administrator has set up video push in Management Client and has enabled you to use video push, you can stream video with audio from your device to your surveillance system. For more information, see Streaming video from your mobile device (explained) and Requirements for using video push.
How you access and use video push depends on the operating system on your device:
  1. Access video push:
    • Android - In the bottom-right corner, tap .
    • iOS - In the navigation bar, tap .
  2. Stream the video from the front-facing or back-facing camera of your device:
    • Android and iOS - tap .
  3. Start streaming video:
    • Android - Tap .
    • iOS - Tap .
  4. Optional. Start audio in the video push:
    • Android and iOS - Tap .
  5. Optional. Stop audio in the video push:
  6. Stop recording:
    • Android - Tap .
    • iOS - Tap .
Bookmark an interesting moment
If you see something that you will want to investigate later, you can bookmark the moment in the video while you are streaming the video from your device to your surveillance system.
To add a bookmark:
  • Android - In the upper-right corner, tap .
  • iOS - In the upper-left corner, tap Bookmark.
On the Bookmarks screen, you can view, edit, or delete the bookmark that you have added. For more information, see Bookmarks (usage).
Investigate the video you streamed
XProtect Mobile records the video that you stream so that you can investigate it.
  1. Go to the view with the video push camera.
  2. Tap the camera to go to full screen.
  3. To play back the recording, tap (Android) or (iOS).
  4. Use the playback controls to investigate the video.
