Blank screen monitoring (explained)
Blank screen monitoring is an operation mode where operators only see video when a situation requires their attention. The video wall does not display any cameras during normal operation. Only when an event occurs does the video wall display video from the related cameras. When the incident has been resolved, the monitors showing the video are cleared.
To enable blank screen monitoring, you must create and apply a preset
Un layout predefinito per uno o più monitor Smart Wall in XProtect Smart Client. Le preimpostazioni determinano le telecamere visualizzate e il modo in cui il contenuto è strutturato su ciascun monitor del videowall. that only has a view layout, but no cameras. Use rules to display the cameras associated with certain events on your video wall, then clear the monitors again. See also Create rules with Smart Wall presets.
