Add a camera to existing investigation
"I want to add more cameras to an existing investigation. How can I do that?"
On the Investigations tab, click to open the side panel.
  1. In the side panel, click Investigations.
  2. Navigate to the investigation that you want to add more cameras to and click on the name of the investigation.
  3. In the side panel, click All cameras. All available cameras appear as thumbnails in the All cameras area.
  4. Navigate to the camera that you want to add and:
    • Click, drag, and drop the camera into the investigation area.
    • Click in the bottom-right corner of each camera .
    • Double-click on the camera that you want to add.
    1. Optional. To reorder the cameras in the investigation, click, drag, and drop the camera that you want to move.
    You can search for a certain camera by name in the Search all cameras field.
    If the check box in the bottom-right corner is selected , the camera has already been added.
  5. Click Save.
  6. In the drop-down list, select Save.
