Recordings from multiple cameras (explained)
You can play back recordings from multiple cameras on both the Views tab and the Investigations tab.
On the Views tab:
  1. In the Views pane section, navigate to a folder with views and click the relevant view. The video starts playing in live mode.
  2. On the timeline bar, click Playback to display the playback timeline (see Using the playback timeline (explained)).
In the view of multiple cameras:
  • See recordings from all cameras in the view.
  • See which of the cameras have microphones attached.
  • See which of the cameras have speakers.
  • Click a camera to view a recording from that camera only. To go back to the view with all cameras, click Back to view.
On the view toolbar:
  • If you want to use the entire screen of your computer when presenting cameras in a view, click to open the Grid view.
On the Investigations tab, you can play back recordings without creating an investigation.
At the bottom of the camera view window, a red sequence line indicates the time snippets where you can find video recordings.
In this mode, you can:
