Check the status of your server connection
In the User profile window, you can check the status of your server connection, for example, to see if you are using an older security model (HTTP) or the newest security model (HTTPS). If multiple sites are connected through Milestone Federated Architecture, you can also check the connected sites.
HTTPS
HTTP
Not connected
Steps:
On the global toolbar, select the User profile button.
- Select Login information and check the status of your connection.
