Home page overview
On the top menu bar, you can use these tabs to do the following:
Item in menu |
What can I do with it? |
Milestone logo |
Click to return to the Home page of XProtect Web Client. |
Views |
Investigations |
Actions |
Activate actions, for example, to open doors (see Activate actions). |
Alarms |
View alarms from all cameras (see View alarms). |
Bookmarks | View the list of bookmarks (see Bookmarks (usage)). |
User menu ![]() |
If you want to exit XProtect Web Client, click ![]() |
More menu ![]() |
Click the More menu to:
The left pane is collapsible. To collapse the pane, click . You can also adjust the pane borders by dragging them to the left-hand or right-hand side.
In the pane, you can navigate to these pane sections to do the following:
Item in menu |
Search for cameras and views
Find a folder, view, or camera. You can filter out the irrelevant items from the list of views. The relevant matches are highlighted (see Search for camera). |
Views |
View videos from one or multiple cameras in live or playback mode. The Views pane section has a Show / Hide option. The Private and Public folders contain lists with subfolders with views inside. |
Cameras | View videos from one camera in live or playback mode. The Cameras pane section has a Show / Hide option. The camera groups and the related devices are organized in lists with folders with cameras inside. |
