Roles (Security node)
Info tab (roles)
Dostupná funkce závisé na vámi používaném systému. Podívejte se na úplný seznam funkcí, který je k dispozici na stránce s přehledem produktu na webu společnosti Milestone (https://www.milestonesys.com/solutions/platform/product-index/).
On the Info tab of a role, you can set the following:
Name |
Description |
| Name |
Enter a name for the role. |
| Description |
Enter a description for the role. |
| Management Client profile |
Select a Management Client profile to associate with the role. You cannot apply this to the default Administrators role. Requires permissions to manage security on the management server. |
| Smart Client profile |
Select a Smart Client profile to associate with the role. Requires permissions to manage security on the management server. |
| Default time profile |
Select a default time profile to associate with the role. You cannot apply this to the default Administrators role. |
| Evidence lock profile |
Select an evidence lock profile to associate with the role. |
| Smart Client login within time profile |
Select a time profile for which the XProtect Smart Client user associated with this role is allowed to log in. If the XProtect Smart Client user is logged in when the period expires, he or she is logged off automatically. You cannot apply this to the default Administrators role. |
| Allow Smart Client login |
Select the check box to allow users associated with this role to log in to XProtect Smart Client. Access to Smart Client is not allowed by default. Clear the check box to deny access to XProtect Smart Client. |
| Allow XProtect Mobile client login |
Select the check box to allow users associated with this role to log in to XProtect Mobile client. Access to XProtect Mobile client is not allowed by default. Clear the check box to deny access to XProtect Mobile client. |
| Allow XProtect Web Client login |
Select the check box to allow users associated with this role to log in to XProtect Web Client. Access to XProtect Web Client is not allowed by default. Clear the check box to deny access to XProtect Web Client. |
| Login authorization required |
Select the check box to associate login authorization with the role. It means that XProtect Smart Client or the Management Client asks for a second authorization, typically by a superuser or manager, when the user logs in. To enable administrators to authorize users, configure the management server's Authorize Users permission on the Overall Security tab. You cannot apply this to the default Administrators role. |
| Make users anonymous during PTZ sessions |
Select the check box to hide the names of users associated with this role when they control PTZ sessions. |
User and Groups tab (roles)
On the User and Groups tab, you assign users and groups to roles (see Assign/remove users and groups to/from roles). You can assign Windows users and groups or basic users (see Users (explained)).
External IDP (roles)
On the External IDP tab, you can view existing claims and add new claims to roles.
Name |
Description |
| External IDP | The name of the external IDP. |
| Claim name | A variable that is defined in the external IDP. |
| Claim value | The value of the claim, such as a group name, that can be used to assign the appropriate role to the user. |
Overall Security tab (roles)
On the Overall Security tab, you set up overall permissions for roles. For every component available in your system, define access permissions for the roles by setting Allow or Deny. When a role is denied access to a component, that component is not visible in the Overall Security tab to a user in that role.
The Overall Security tab is not available in the free XProtect Essential+.
You can define more access permissions for XProtect Corporate than for the other XProtect VMS products. This is because you can only set up differentiated administrator permissions in XProtect Corporate, while you can set up overall permissions for a role that uses XProtect Smart Client, XProtect Web Client, or XProtect Mobile client in all products.
The overall security settings only apply to the current site.
If you associate a user with more than one role and select Deny on a security setting for one role and Allow for another, the Deny permission overrules the Allow permission.
In the following, the descriptions show what happens on each individual permission for the different system components if you select Allow for the relevant role. If you use XProtect Corporate, you can see which settings are available only to your system under each system component.
For every system component or functionality, the full system administrator can use the Allow or Deny check boxes to set up security permissions for the role. Any security permissions that you set up here are set up for the whole system component or functionality. If, for example, you select the Deny check box on Cameras, all cameras added to the system are unavailable for the role. In contrast, if you select the Allow check box, the role can see all cameras added to the system. The result of selecting Allow or Deny on your cameras is that the camera settings on the Device tab then inherit your selections on the Overall Security tab so that either all cameras are either available or unavailable to the particular role.
If you want to set security permissions for individual cameras or similar, you can only set these individual permissions on the tab of the relevant system component or functionality if you have not set any overall permissions for the system component or functionality on the Overall Security tab.
The descriptions below also apply to the permissions that you can configure through the MIP SDKs.
If you want to switch your base license from XProtect Corporate to one of the other products, make sure that you remove all security permissions that are available to only XProtect Corporate. If you do not remove those permissions, you cannot complete the switch.
Security permission |
Description |
| Full control |
Enables the permission to manage all security entries on this part of the system. |
| Connect |
Enables users to connect to the Management Server. This permission is enabled by default. You can temporarily deny connection permission on roles for maintenance purposes, and then reapply access to the system. This permission must be selected to allow access to the system. |
| Read |
This permission is a highly privileged administrative permission that gives significant access rights to the XProtect VMS, including access to sensitive data such as credentials configured in the system. Enables the permission to access a wide range of functionality, including:
It also enables access to:
This permission also reveals some sensitive information to the client:
This permission does not reveal credentials for users of the XProtect VMS. This includes Basic Users, Windows users and users from external IDPs. |
| Edit |
Enables the permission to modify data in a wide range of functionality, including:
It also enables users to create, delete, and edit the following:
Enables the permission to configure local IP ranges when configuring the network on the recording server. |
| System Monitor |
Enables the permission to view the data of the System Monitor. |
| Status API |
Enables the permission to perform queries on the Status API located on the recording server. This means that the role with this permission enabled has access to read the status of the items located on the recording server. |
| Manage Federated site hierarchy |
Enables the permission to add and detach the current site to other sites in a federated site hierarchy. If you set this permission to allowed on the child site only, the user can still detach the site from the parent site. |
| Backup Configuration |
Enables the permission to create backups of the system configuration using the system's backup and restore functionality. |
| Authorize users |
Enables the permission to authorize users when they are asked for a second login in XProtect Smart Client or Management Client. You define if a role requires login authorization on the Infotab. |
| Manage security |
Enables the permission to manage permissions for the Management Server. It also enables users to create, delete, and edit the following features:
Description |
| Full control |
| Edit |
Enables the permission to edit properties on the recording servers, except for network configuration settings that require edit permission on the management server. |
| Delete |
Enables the permission to delete recording servers. To do this, you must also give the user delete permissions on:
If any of the devices on the recording server contains evidence locks, you can only delete the recording server if it is offline. |
| Manage hardware |
Enables the permission to add hardware on recording servers. |
| Manage storage |
Enables the permission to administrate storage containers on recording server, that is, to create, delete, move, and empty storage containers. |
| Manage security |
Enables the permission to manage security permissions for recording servers. |
Description |
| Full control |
| Read |
Enables the permission to see and access failover servers in the Management Client. |
| Edit |
Enables the permission to create, update, delete, move, and enable or disable failover servers in the Management Client. |
| Manage security |
Enables the permission to manage security permissions for the failover servers. |
Description |
| Full control |
| Read |
Enables the permission to see and access mobile servers in the Management Client. |
| Edit |
Enables the permission to edit and delete mobile servers in the Management Client. |
| Manage security |
Enables the permission to manage security permissions for the mobile servers. |
| Create |
Enables the permission to add mobile servers to the system. |
Description |
| Full control |
| Edit |
Enables the permission to edit properties on hardware. |
| Delete |
Enables the permission to delete hardware. If any of the hardware devices contains evidence locks, you can only delete the hardware if the recording server is offline. |
| Driver commands |
Enables the permission to send special commands to the drivers and thereby control features and configuration on the device itself. The Driver commands permission is for special developed MIP plug-ins in the clients only. It does not control standard configuration tasks. |
| View passwords | Enables the permission to view passwords on hardware devices in the Edit Hardware dialog box. |
| Manage security |
Enables the permission to manage security permissions for the hardware. |
Description |
| Full control |
| Read |
Enables the permission to view camera devices in the clients and the Management Client. |
| Edit |
Enables the permission to edit properties for cameras in the Management Client. It also enables users to enable or disable a camera. |
| View Live |
Enables the permission to view live video from cameras in the clients and the Management Client. |
| Playback |
Enables the permission to play back recorded video from cameras in the clients and the Management Client. |
| Retrieve remote recordings |
Enables the permission to retrieve recordings in the clients from cameras on remotes sites or from edge storages on cameras. |
| Read sequences |
Enables the permission to read the sequence information related to, for example, playing back recorded video in the clients. |
| Smart search |
Enables the permission to use the Smart search function in the clients. |
| Export |
Enables the permission to export recordings from the clients. |
| Create bookmarks |
Enables the permission to create bookmarks in recorded and live video in the clients. |
| Read bookmarks |
Enables the permission to search for and read bookmark details in the clients. |
| Edit bookmarks |
Enables the permission to edit bookmarks in the clients. |
| Delete bookmarks |
Enables the permission to delete bookmarks in the clients. |
| Create and extend evidence locks |
Enables the permission to create and extend evidence locks in the clients. |
| Read evidence locks |
Enables the permission to search and read evidence locks in the clients. |
| Delete and reduce evidence locks |
Enables the permission to delete or reduce evidence locks in the clients. |
| Start manual recording |
Enables the permission to start manual recording of video in the clients. |
| Stop manual recording |
Enables the permission to stop manual recording of video in the clients. |
| AUX commands |
Enables the permission to use auxiliary (AUX) commands on the camera from the clients. AUX commands offer users the control of, for example, wipers on a camera connected via a video encoder. Camera-associated devices connected via auxiliary connections are controlled from the client. |
| Manual PTZ |
Enables the permission to use PTZ functions on PTZ cameras in the clients and the Management Client. |
| Activate PTZ presets or patrolling profiles |
Enables the permission to move PTZ cameras to preset positions, start and stop patrolling profiles, and pause a patrolling in the clients and the Management Client. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
| Manage PTZ presets or patrolling profiles |
Enables the permission to add, edit, and delete PTZ presets and patrolling profiles on PTZ cameras in the clients and the Management Client. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
| Lock/unlock PTZ presets |
Enables the permission to lock and unlock PTZ presets in the Management Client. This prevents or allows other users from changing preset positions in the clients and in the Management Client. |
| Reserve PTZ sessions |
Enables the permission to set PTZ cameras in reserved PTZ session mode in the clients and the Management Client. In a reserved PTZ session, other users with higher PTZ priority are not able to take over the control. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
| Release PTZ sessions |
Enables the permission to release other users' PTZ sessions from the Management Client. You can always release your own PTZ sessions - without this permission. |
| Delete recordings |
Enables the permission to delete stored video recordings from the system via the Management Client. |
| Lift privacy masks |
Enables the permission to temporarily lift privacy masks in XProtect Smart Client. It also enables the permission to authorize other XProtect Smart Client users to lift privacy masks. Lifting privacy masks only applies to privacy masks configured as liftable privacy masks in the Management Client. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for the camera. |
Description |
| Full control |
| Read |
Enables the permission to view microphone devices in the clients and the Management Client. |
| Edit |
Enables the permission to edit microphone properties in the Management Client. It also allows users to enable or disable microphones. |
| Listen Live |
Enables the permission to listen to live audio from speakers in the clients and the Management Client. |
| Playback |
Enables the permission to play back recorded audio from microphones in the clients. |
Enables the permission to retrieve recordings in the clients from microphones on remotes sites or from edge storages on cameras. |
| Read sequences |
Enables the permission to read the sequence information related to, for example, the Playback mode in the clients. |
| Export |
| Create bookmarks |
Enables the permission to create bookmarks in the clients. |
| Read bookmarks |
| Edit bookmarks |
| Delete bookmarks |
Enables the permission to create or extend evidence locks in the clients. |
Enables the permission to search and read evidence lock details in the clients. |
Enables the permission to start manual recording of audio in the clients. |
Enables the permission to stop manual recording of audio in the clients. |
| Delete recordings |
Enables the permission to delete stored recordings from the system. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for microphones. |
Description |
| Full control |
| Read |
Enables the permission to view speaker devices in the clients and the Management Client. |
| Edit |
Enables the permission to edit properties for speakers in the Management Client. It also allows users to enable or disable speakers. |
| Listen live |
| Speak |
Enables the permission to speak through the speakers in the clients. |
| Playback |
Enables the permission to play back recorded audio from speakers in the clients. |
Enables the permission to retrieve recordings in the clients from speakers on remotes sites or from edge storages on cameras. |
| Read sequences |
Enables the permission to use the Sequences feature while browsing recorded audio from speakers in the clients. |
| Export |
Enables the permission to export recorded audio from speakers in the clients. |
| Create bookmarks |
| Read bookmarks |
| Edit bookmarks |
| Delete bookmarks |
Enables the permission to create or extend evidence locks to protect recorded audio in the clients. |
Enables the permission to view recorded audio protected by evidence locks in the clients. |
Enables the permission to delete or reduce evidence locks on protected audio in the clients. |
| Delete recordings |
| Manage security |
Enables the permission to manage security permissions in the Management Client for speakers. |
Description |
| Full control |
| Read |
Enables the permission to receive metadata in the clients. |
| Edit |
Enables the permission to edit metadata properties in the Management Client. It also allows users to enable or disable metadata devices. |
| Live |
Enables the permission to receive live metadata from metadata devices in the clients. |
| Playback |
Enables the permission to play back recorded data from metadata devices in the clients. |
Enables the permission to retrieve recordings in the clients from metadata devices on remotes sites or from edge storages on cameras. |
| Read sequences |
| Export |
Enables the permission to export recordings in the clients. |
Enables the permission to create evidence locks in the clients. |
Enables the permission to view evidence locks in the clients. |
Enables the permission to start manual recording of metadata in the clients. |
Enables the permission to stop manual recording of metadata in the clients. |
| Delete recordings |
| Manage security |
Enables the permission to manage security permissions in the Management Client for metadata. |
Description |
| Full control |
| Read |
Enables the permission to view input devices in the clients and the Management Client. |
| Edit |
Enables the permission to edit properties for input devices in the Management Client. It also enables users to enable or disable an input device. |
| Manage security |
Enables the permission to manage security permissions in the Management Clientfor input devices. |
Description |
| Full control |
| Read |
Enables the permission to view output devices in the clients. |
| Edit |
Enables the permission to edit properties for output devices in the Management Client. It also enables users to enable or disable an output device. |
| Activate |
Enables the permission to activate outputs in the clients. |
| Manage security |
Enables the permission to manage security permissions in the Management Clientfor output devices. |
Description |
| Full control |
Enables the permission to manage all security permissions in XProtect Management Client. |
| Read |
Enables the permission to view a video wall in XProtect Smart Client. |
| Edit |
Enables the permission to edit properties for the Smart Wall definition in XProtect Management Client. |
| Delete |
Enables the permission to delete existing Smart Wall definitions in XProtect Management Client. |
| Operate |
Enables the permission to activate and modify Smart Wall definitions, for example to change and activate presets or apply cameras on views in XProtect Smart Client and in XProtect Management Client. You can associate Operate with time profiles that define when the user permission applies. |
| Create Smart Wall |
Enables the permission to create new Smart Wall definitions in XProtect Management Client. |
| Manage security |
Enables the permission to manage security permissions in XProtect Management Client for the Smart Wall definition. |
| Playback |
Enables the permission to play back recorded data from a video wall in XProtect Smart Client. You can associate Playback with time profiles that define when the user permission applies. |
Description |
| Full control |
| Read |
Enables the permission to view View Groups in the clients and in the Management Client. View groups are created in the Management Client. |
| Edit |
Enables the permission to edit properties on the View Groups in the Management Client. |
| Delete |
Enables the permission to delete View Groups in the Management Client. |
| Operate |
Enables the permission to use View Groups in XProtect Smart Client, that is, to create and delete subgroups and views. |
| Create view group |
Enables the permission to create View Groups in the Management Client. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for View Groups. |
Description |
| Full control |
| Read |
Enables the permission to view user-defined events in the clients. |
| Edit |
Enables the permission to edit properties on user-defined events in the Management Client. |
| Delete |
Enables the permission to delete user-defined events in the Management Client. |
| Trigger |
Enables the permission to trigger user-defined events in the clients. |
| Manage security |
Enables the permission to manage security permissions in the Management Clientfor user-defined events. |
| Create user-defined event |
Enables the permission to create new user-defined events in the Management Client. |
Description |
| Full control |
| Read |
Enables the permission to view analytics events in the Management Client. |
| Edit |
Enables the permission to edit properties on analytics events in the Management Client. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for analytics events. |
Description |
| Full control |
| Read |
Enables the permission to view generic events in the clients and the Management Client. |
| Edit |
Enables the permission to edit properties on generic events in the Management Client. |
| Manage security |
Enables the permission to manage security permissions in the Management Clientfor generic events. |
Description |
| Full control |
| Read |
Enables the permission to select and send video to the Matrix recipient from the clients. |
| Edit |
Enables the permission to edit properties for a Matrix in the Management Client. |
| Delete |
Enables the permission to delete a Matrix in the Management Client. |
| Create Matrix |
Enables the permission to create a new Matrix in the Management Client. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for all Matrix's. |
Description |
| Full control |
| Read |
Enables the permission to view existing rules in the Management Client. |
| Edit |
Enables the permission to edit properties for rules and to define rule behavior in the Management Client. It also requires that the user has read permissions on all the devices that are impacted by the rule. |
| Delete |
Enables the permission to delete rules from the Management Client. It also requires that the user has read permissions on all devices that are impacted by the rule. |
| Create rule |
Enables the permission to create new rules in the Management Client. It also requires that the user has read permissions on all devices that are impacted by the rule. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for all rules. |
Description |
| Full control |
| Read |
Enables the permission to view other sites in the Management Client. Connected sites are connected via Milestone Federated Architecture. To edit properties, you need Edit permissions on the Management Server on each site. |
| Manage security |
Enables the permission to manage security permissions on all sites. |
Description |
| Full control |
| Read |
Enables the permission to view system monitors in XProtect Smart Client. |
| Edit |
Enables the permission to edit properties for system monitors in the Management Client. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for all system monitors. |
Description |
| Full control |
| Read |
Enables the permission to view the Metadata Use functionality in Management Client and its related settings, but does not enable the permission to change the settings. |
| Edit the metadata search configuration |
Enables the permission to enable or disable metadata search categories, for example metadata for people or vehicles, in the Management Client. |
| Manage security |
Enables the permission to manage security permissions for metadata searches. |
Description |
| Read public searches | Enables the permission to view and open saved public searches in XProtect Smart Client. |
| Create public searches | Enables the permission to save newly configured searches as public searches in XProtect Smart Client. |
| Edit public searches | Enables the permission to edit the details or the configuration of saved public searches in XProtect Smart Client, for example the name, description, cameras, and search categories. |
| Delete public searches | Enables the permission to delete saved public searches. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for search. |
Description |
| Full control |
| Manage |
Enables the permission to manage alarms in the Management Client. For example, change priorities of alarms and re-delegate alarms to other users, acknowledge alarms and change the state, for example, from New to Assigned, of several alarms at the same time iew alarm definitions, alarm sounds, and alarm data settings. Only when you set this to allowed does the Alarms and Events tab in the Options dialog appear. |
| Edit |
Enables the permission to view alarms and print alarm reports. |
| Disable alarms |
Enables the permission to disable alarms. |
| Receive notifications | Enables the permission to receive notifications about alarms in XProtect Mobile clients and XProtect Web Client. |
| Manage security |
Enables the permission to manage security permissions for alarms. |
| Create |
Enables the permission to create new alarm definitions in the Management Client. |
Description |
| Full control |
| Read system log entries | Enables the permission to see system log entries. |
| Read audit log entries | Enables the permission to see audit log entries. |
| Read rule-triggered log entries | Enables the permission to see rule-triggered log entries. |
| Read log configuration | Enables the permission to read log settings in Tools > Options > Server Logs. |
| Update log configuration | Enables the permission to change log settings in Tools > Options > Server Logs. |
| Manage security |
Description |
| Full control |
| Edit |
Enables the permission to edit properties for the Access Control systems in the Management Client. |
| Use access control | Allows the user to use any access control-related features in the clients. |
| View cardholders list | Allows the user to view the cardholders list on the Access Control tab in the clients. |
| Receive notifications | Allows the user to receive notifications about access requests in the clients. |
| Manage security |
Enables the permission to manage security permissions for all Access Control systems. |
If your system runs with XProtect LPR, specify the following permissions for the user:
Description |
| Full control |
| Use LPR |
Enables the permission to use any LPR-related features in the clients |
Manage match lists |
Enables the permission to add, import, modify, export, and delete match lists in the Management Client. |
| Read match lists |
Enables the permission to view match lists. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for all Transaction definitions. |
Description |
| Full control |
| Read |
Enables the permission to view properties for the Transaction sources in the Management Client. |
| Edit |
Enables the permission to edit properties for the Transaction sources in the Management Client. |
| Delete |
Enables the permission to delete Transaction sources in the Management Client. |
| Create |
Enables the permission to create new Transaction sources in the Management Client. |
| Manage security |
Enables the permission to manage security permissions in the Management Client for all Transaction sources. |
Description |
| Full control |
| Read |
Enables the permission to view properties for the Transaction definitions in the Management Client. |
| Edit |
Enables the permission to edit properties for the Transaction definitions in the Management Client. |
| Delete |
Enables the permission to delete Transaction definitions in the Management Client. |
| Create |
Enables the permission to create new Transaction definitions in the Management Client. |
| Manage security |
Through the MIP SDK, a third-party vendor can develop custom plug-ins for your system, for example, integration to external access control systems or similar functionality.
Device tab (roles)
The Device tab lets you specify which features users/groups with the selected role can use for each device (for example, a camera) or device group in XProtect Smart Client.
Remember to repeat for each device. You can also select a device group, and specify role permissions for all the devices in the group in one go.
You can still select or clear such square-filled check boxes, but note that your choice in that case applies for all devices within the device group. Alternatively, select the individual devices in the device group to verify exactly which devices the relevant permission applies for.
Camera-related permissions
Specify the following permissions for camera devices:
Name |
Description |
| Read |
The selected camera(s) will be visible in the clients. |
| View live |
Allows live viewing of video from the selected camera(s) in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view live video in the clients. This permission is granted as part of the application permissions. Specify the time profile or leave the default value. |
| Playback > Within time profile |
Allows playback of recorded video from the selected camera(s) in the clients. Specify the time profile or leave the default value. |
| Playback > Limit playback to |
Allows playback of recorded video from the selected camera(s) in the clients. Specify a playback limit or apply no restrictions. |
| Read sequences |
Allows reading the sequence information related to, for example, the Sequence explorer in the clients. |
| Smart search |
Allows the user to use the Smart search function in the clients. |
| Export |
Allows the user to export recordings from the clients. |
Allows starting manual recording of video from the selected camera(s) in the clients. |
Allows stopping manual recording of video from the selected camera(s) in the clients. |
| Read bookmarks |
Allows search for and read bookmark details in the clients. |
| Edit bookmarks |
Allows editing bookmarks in the clients. |
| Create bookmarks |
Allows adding bookmarks in the clients. |
| Delete bookmarks |
Allows deleting bookmarks in the clients. |
| AUX commands |
Allows the use of auxiliary commands from the clients. |
Allows the client user to:
Requires user permissions to all devices included in the evidence lock. |
Allows the client user to search for and read evidence lock details. |
Microphone-related permissions
Specify the following permissions for microphone devices:
Name |
Description |
| Read |
The selected microphone(s) will be visible in the clients. |
| Listen live |
Allows listening to live audio from the selected microphones in the clients. |
Allows playback of recorded audio from the selected microphone(s) in the clients. Specify the time profile or leave the default value. |
Allows playback of recorded audio from the selected microphone(s) in the clients. Specify a playback limit or apply no restrictions. |
| Read sequences |
| Export |
Allows starting manual recording of audio from the selected microphone(s) in the clients. |
Allows stopping manual recording of audio from the selected microphone(s) in the clients. |
| Read bookmarks |
| Edit bookmarks |
| Create bookmarks |
| Delete bookmarks |
Speaker-related permissions
Specify the following permissions for speaker devices:
Name |
Description |
| Read |
The selected speaker(s) is visible in the clients. |
| Listen live |
Allows listening to live audio from the selected speaker(s) in the clients. |
Allows playback of recorded audio from the selected speaker(s) in the clients. Specify the time profile or leave the default value. |
Allows playback of recorded audio from the selected speaker(s) in the clients. Specify a playback limit or apply no restrictions. |
| Read sequences |
| Export |
Allows starting manual recording of audio from the selected speaker(s) in the clients. |
Allows stopping manual recording of audio from the selected speaker(s) in the clients. |
| Read bookmarks |
| Edit bookmarks |
| Create bookmarks |
| Delete bookmarks |
Metadata-related permissions
Specify the following permissions for metadata devices:
Name |
Description |
| Read |
Enables the permission to see metadata devices and retrieve data from them in the clients. |
| Edit |
Enables the permission to edit metadata properties. It also allows users to enable or disable metadata devices in the Management Client |
| View Live |
Enables the permission to view live metadata from cameras in the clients. For XProtect Smart Client, it requires that the role has been granted the permission to view live video in the clients. This permission is granted as part of the application permissions. |
| Playback |
| Read sequences |
Enables the permission to use the Sequences feature while browsing recorded data from metadata devices in the clients. |
| Export |
Enables the permission to export recorded audio from metadata devices in the clients. |
Enables the permission to create and extend the evidence locks on metadata in the clients. |
Enables the permission to view evidence locks on metadata in the clients. |
Enables the permission to delete or reduce evidence locks on metadata in the clients. |
Input-related permissions
Specify the following permissions for input devices:
Name |
Description |
| Read |
The selected input(s) will be visible in the clients. |
Output-related permissions
Specify the following permissions for output devices:
Name |
Description |
| Read |
The selected output(s) will be visible in the clients. If visible, the output will be selectable on a list in the clients. |
| Activate |
The selected output(s) can be activated from the Management Client and the clients. Specify the time profile or leave the default value. |
PTZ tab (roles)
You set up permissions for pan-tilt-zoom (PTZ) cameras on the PTZ tab. You can specify the features users/groups can use in the clients. You can select individual PTZ cameras or device groups containing PTZ cameras.
Specify the following permissions for PTZ:
Name |
Description |
| Manual PTZ |
Determines if the selected role can use PTZ functions and pause a patrolling on the selected camera. Specify a time profile, select Always, or leave the default value that follows the default time profile defined on the Info tab for that role. |
Determines if the selected role can move the selected camera to preset positions, start and stop patrolling profiles, and pause a patrolling. Specify a time profile, select Always, or leave the default value that follows the default time profile defined on the Info tab for that role. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
| PTZ Priority |
Determines the priority of PTZ cameras. When several users on a surveillance system want to control the same PTZ camera at the same time, conflicts may occur. You can avoid such a situation by specifying a priority for use of the selected PTZ camera(s) by users/groups with the selected role. Specify a priority from 1 to 32,000, where 1 is the lowest priority. The default priority is 3,000. The role with the highest priority number is the one who can control the PTZ camera(s). |
Determines the permission to add, edit and delete PTZ presets and patrolling profiles on the selected camera in both the Management Client and XProtect Smart Client. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
Determines if the role can lock and unlock preset positions for the selected camera. |
Determines the permission to set the selected camera in reserved PTZ session mode. In a reserved PTZ session other users or patrolling sessions with higher PTZ priority are not able to take over the control. To allow this role to use other PTZ functions on the camera, enable the Manual PTZ permission. |
Determines if the selected role can release other users' PTZ sessions from the Management Client. You can always release your own PTZ sessions - without this permission. |
Speech tab (roles)
Relevant only if you use speakers on your system. Specify the following permissions for speakers:
Name |
Description |
| Speak |
Determine if users should be allowed to talk through the selected speaker(s). Specify the time profile or leave the default value. |
| Speak priority |
When several client users want to talk through the same speaker at the same time, conflicts may occur. Solve the problem by specifying a priority for use of the selected speaker(s) by users/groups with the selected role. Specify a priority from Very low to Very high. The role with the highest priority is allowed use the speaker before other roles. Should two users with the same role want to speak at the same time, the first come, first served-principle applies. |
Remote Recordings tab (roles)
Specify the following permissions for remote recordings:
Name |
Description |
Enables the permission to retrieve recordings in the clients from cameras, microphones, speakers, and metadata devices on remotes sites or from edge storages on cameras. |
Smart Wall tab (roles)
Through roles, you can grant your client users Smart Wall-related user permissions:
Name |
Description |
| Read |
Allows users to view the selected Smart Wall in XProtect Smart Client. |
| Edit |
Allows users to edit the selected Smart Wall in the Management Client. |
| Delete |
Allows users to delete the selected Smart Wall in the Management Client. |
| Operate |
Allows users to apply layouts on the selected Smart Wall in XProtect Smart Client and to activate presets. |
| Playback |
Allows users to play back recorded data from the selected Smart Wall in XProtect Smart Client. |
External Event tab (roles)
Specify the following external event permissions:
Name |
Description |
| Read |
Allows users to search for and view the selected external system event in the clients and the Management Client. |
| Edit |
Allows users to edit the selected external system event in the Management Client. |
| Delete |
Allows users to delete the selected external system event in the Management Client. |
| Trigger |
Allows users to trigger the selected external system event in the clients. |
View Group tab (roles)
On the View Group tab, you specify which view groups the users and user groups with the selected role can use in the clients.
Specify the following permissions for view groups:
Name |
Description |
| Read |
Enables the permission to view the View Groups in the clients and in the Management Client. View groups are created in the Management Client. |
| Edit |
Enables the permission to edit properties on View Groups in the Management Client. |
| Delete |
| Operate |
Enables the permission to use View Groups in XProtect Smart Client, that is to create and delete subgroups and views. |
Servers tab (roles)
Specifying role permissions on the Servers tab is only relevant if your system works in a Milestone Federated Architecture setup.
Name |
Description |
| Sites |
Enables the permission to view the selected site in the Management Client. Connected sites are connected via Milestone Federated Architecture. To edit properties, you need Edit permissions on the Management Server on each site. |
See Configuring Milestone Federated Architecture for more information.
Matrix tab (roles)
If you have configured Matrix recipients on your system, you may configure Matrix role permissions. From a client, you can send video to selected Matrix recipients. Select the users who can receive this on the Matrix tab.
The following permissions are available:
Name |
Description |
| Read |
Determine if users and groups with the selected role can select and send video to the Matrix recipient from the clients. |
Alarms tab (roles)
If you use alarms in your system setup to provide central overview and control of your installation (including any other XProtect servers), you can use the Alarms tab to specify the alarm permissions for users and groups with the selected role they should have, for example, how to handle alarms in the clients.
Specify the following permissions for alarms:
Name |
Description |
| Manage |
Enables the permission to manage alarms, for example changing priorities of alarms and re-delegate alarms to other users, acknowledge alarms and change the state, for example from New to Assigned, of several alarms at the same time. |
| View |
| Disable alarms |
Access Control tab (roles)
When you add or edit basic users, Windows users or groups, specify access control settings:
Name |
Description |
LPR tab (roles)
If your system runs with XProtect LPR, specify the following permissions for the users:
Name |
Description |
| Use LPR |
Enables the permission to use any LPR-related features in the clients. |
| Read match lists |
Incidents tab (roles)
If you have XProtect Incident Manager, you can specify the following permissions for your roles.
To give a Management Client administrator role the permissions to manage or view incident properties, select the Incident properties node.
To give an operator of XProtect Smart Client permission to view your defined incident properties, select Incident properties and give View permission. To give general permissions to manage or view incident projects, select the Incident project node. Expand the Incident project node and select one or more sub-nodes to give permissions for these additional specific features or capabilities.
Name |
Description |
| Manage |
Permission to manage (view, create, edit, and delete) settings and properties related to a feature or view a user interface element represented by the selected node in either Management Client or XProtect Smart Client. |
| View |
Permission to view (but not create, edit, and delete) the settings and properties related to a feature, view defined incident properties, or view a user interface element represented by the selected node in either Management Client or XProtect Smart Client. |
MIP tab (roles)
The settings you change depend on the actual plug-in. Find the custom settings for the plug-ins on the MIPtab.
