XProtect Smart Wall
XProtect Smart Wall is an advanced extension that enables organizations to create video walls that meet their specific security demands. XProtect Smart Wall provides an overview of all the video data in the XProtect VMS
Short for "Video Management Software". system and supports any amount or combination of monitors.
If your organization uses the XProtect Smart Wall extension, there are several physical displays that constitute a video wall. You can also send content to the video wall by selecting the camera’s view item, then select More and Send to Smart Wall.
XProtect Smart Wall allows operators to view static video walls as defined by their system administrator with a fixed set of cameras and monitor layout. However, the video wall is also operator-driven in the sense that operators can control what is being displayed. This includes:
- Pushing cameras and other types of content to the video wall, for example images, text, alarms, and smart map
- Sending entire views to the monitors
- In the course of certain events, applying alternate presets
A predefined layout for one or more Smart Wall monitors in XProtect Smart Client. Presets determine which cameras are displayed, and how content is structured on each monitor on the video wall.
See also Smart Wall control (explained).
Finally, display changes can be controlled by rules that automatically change the presets based on specific events or time schedules.
See also the separate XProtect Smart Wall manual.
