Disable the help
To prevent operatorsClosedA professional user of an XProtect client application. from accessing the help function, you can disable the help. Then nothing happens when you press F1, and the context-sensitive links and Help buttons are no longer visible. If required, you can enable the help again.
Steps:
  1. On the global toolbar, select Settings and more and then Settings to open the Settings window.
    Open the Settings window in XProtect Smart Client.
  2. From the Application tab and in the Help list, select Unavailable.
  3. Close the dialog.
  4. To test that the help has been disabled, press F1. Nothing should happen.
