Bookmarks (configuration)
This feature is only available in certain XProtect VMS systems. For more information, see the product comparison chart: https://www.milestonesys.com/products/software/product-index/
Enable detailed bookmarks
To be able to give bookmarks a name and a description and changing the default time span, you must enable details.
Steps:
On the global toolbar, select Settings and more
and then Settings
to open the Settings window.
- Select the Functions tab.
- To enable detailed bookmarks for live video, switch to live mode and select Add bookmark details in the Bookmark list.
- To enable detailed bookmarks for recorded video, switch to playback mode and select Add bookmark details in the Bookmark list.
- Click Close.
