Log in and log out
Log in
  1. Start XProtect Smart Client. The login window appears.
    Login window in XProtect Smart Client.
  2. Specify the name or address of the server that you want to connect to.
  3. Select one of these authentication methods:
  4. Click Connect. If a problem occurs during login, you may receive an error message. See also Logging in (troubleshooting).
  5. Depending on the configuration, you may be asked to restore the views used in the previous session:
    • Main view - this option restores the view that you used last time in the main window
    • Detached views - this option restores the view that you used last time in a floating window. Only available when connecting to specific XProtect VMS systems. See also Surveillance system differences.
If you encounter a second dialog during login, you need additional login authorization to get access to XProtect Smart Client.
Log out
  1. On the global toolbar, select User menu.
  2. Select Log out.
Smart Client restarts and the login window is shown so you can log in again.
See also Logging in and out.
