Patrolling profiles (configuration)
Depending on your surveillance system (see Surveillance system differences), you can create, edit, and delete patrolling profiles.
Add patrolling profile
When you add a patrolling profileClosedThe exact definition of how patrolling with a PTZ camera is carried out, including the sequence for moving between preset positions, timing settings, etc. Also known as a "patrol scheme"., you and other users can see the new patrolling profile in the PTZ menu.
  1. In the view, select the relevant PTZ camera where you want to add a new patrolling profile.
  2. On the camera toolbar, click the PTZ icon to open the PTZ menu.
  3. Click Manage patrolling profiles to open the dialog box.
  4. Follow the steps below and click OK to close the Manage patrolling profiles window.
  5. Click below the Patrolling profiles list to add a new patrolling profile.
  6. Enter a name for the profile and press Enter. You can always rename it later.
    The new patrolling profile is added to the Patrolling profiles list. You can now specify the positions and other settings for the patrolling profile.
Delete patrolling profile
To delete an existing profile, select the profile and click .
Edit patrolling profile
Specify positions in a patrolling profile
  1. Select the patrolling profile:
  2. Click below the Positions list to add a PTZ presetClosedCan be used for making the PTZ camera automatically go to particular preset positions when particular events occur, and for specifying PTZ patrolling profiles..
    PTZ presets are defined by your system administrator. Depending on your user permissions, you can define PTZ presets by selecting Manage PTZ presets (see PTZ presets (configuration)).
  3. In the list, select a PTZ preset.
  4. Repeat adding presets until you have selected all necessary positions in the patrolling profile:
    Positions in a patrolling profile.
  5. Use the up or down arrows to move a PTZ preset in the list.
    The camera uses the PTZ preset at the top of the list as the first stop when it patrols according to the patrolling profile. The PTZ preset in the second position from the top is the second stop, and so forth.
