Bookmarks (configuration)
This feature is only available in certain XProtect VMS systems. For more information, see the product comparison chart: https://www.milestonesys.com/solutions/platform/product-index/
Enable detailed bookmarks
To be able to give bookmarks a name and a description and changing the default time span, you must enable details.
Steps:
  1. On the global toolbar, select Settings and more and then Settings to open the Settings window.
    Open the Settings window in XProtect Smart Client.
  2. Select the Functions tab.
  3. To enable detailed bookmarks for live video, switch to live mode and select Add bookmark details in the Bookmark list.
  4. To enable detailed bookmarks for recorded video, switch to playback mode and select Add bookmark details in the Bookmark list.
  5. Click Close.
