Change the behavior of a node after restart
By default, if a node restarts, it keeps its previous state. You can change that behavior and make a node to always start or stop after restart.
On a computer that has access to the failover cluster, open a browser and specify the URL of the failover web console using this format: http://[computername.domainname]:9010 or https://[computername.domainname]:9453.
The [computername.domainname] is the FQDN of the primary or the secondary computer.
On the primary or the secondary computer, double-click the icon of the XProtect Management Server Failover web console on your desktop.
(For initial connection over HTTPS only) Select a user certificate to access the failover web console and specify the password.
To log in to the failover web console, you must authenticate with the user name admin and the password you set during the configuration of the failover cluster. If you do not remember your password, see Change the password for authentication.
Select the arrow next to a node and select Admin > Configure boot start.
From the Module start at boot time window, select:
enabled - the node starts automatically after restart and comes into SECOND state.
disabled - the node comes into STOP state after restart. You can start the node manually from the failover web console.
To revert to the default behavior and set the node to keep the state from before the restart, you need to remove the existing failover configuration and configure the failover cluster again.
