CCure 9000: licenses explained
Licenses required for CCure 9000 change based on the version of software installed. For versions 2.9 and below, there are two licenses required.
The CCure 9000 license required to integrate with Milestone XProtect is “Milestone XProtect Corporate” or "Milestone - XProtect Corporate." This doesn't mean that the only XProtect product that integrates with CCure 9000 is XProtect Corporate. XProtect Corporate, XProtect Expert, and XProtect Professional+ VMS products from Milestone are all tested and supported.
There are three different types of Milestone XProtect Corporate licenses based on the size of the CCure system (the number of readers). These license options apply to all versions of CCure 9000.
License SKU | Description |
CC9-MSTVD-SM | CCure 9000 Milestone XProtect Corporate Web Service Integration Small, Series L to N (0-64 readers) |
CC9-MSTVD-MD | CCure 9000 Milestone XProtect Coporate Web Service Integration Medium, Series P to R (65-999 readers) |
CC9-MSTVD-LG | CCure 9000 Milestone XProtect Corporate Web Service Integration Large, Series RP to T (1000+ readers) |
XProtect Access uses a permanent connection to the CCure 9000victor web service (to receive statuses and events) and uses extra connections for specific user operations, such as fetching configuration and executing commands. For optimal operation of XProtect Access, the feature license activated in CCure must support enough concurrent connections to the victor web service to handle the number of XProtect Access permanent and transient connections.
The victor web service is a requirement for the XProtect Access integration with CCure 9000. This licensed option is typically included free of charge, on all current CCure 9000 systems.
