View user activity log entries for an incident project
The VMS writes log entries for every incident project when you or others make changes to an incident project. The log entries list what has been changed, by whom, and when the change was saved.
- Select the Incidents tab and double-click the incident project that you want to open.
- Select the Activity logs tab.
- Creates, edits, and opens an incident project.
- Applies and changes values for types, statuses, and categories.
- Adds, edits, and deletes comments or information about calls.
- Sends an incident project for export.
- Generates and prints an incident project report.
- Adds and removes sequences.
- Review the activity log entries.
If you can't find a specific incident project, you can use the filter options. See Filter for incident projects.
The activity log entries show information about when a user:
