Configuring the Milestone Open Network Bridge
After you install the Milestone Open Network Bridge, the Milestone Open Network Bridge service is running and the Milestone Open Network Bridge Manager tray icon turns green.
You must first configure access rights, which is described in Setting up Milestone Open Network Bridge security controls.
The next step is to add the Milestone Open Network Bridge plug-in to the Management Client.
Add Milestone Open Network Bridge to the Management Client:
- Open the Management Client.
Expand Servers, right-click Milestone Open Network Bridge, and select Add New.
The Add Milestone Open Network Bridge dialog box lists all registered Add Milestone Open Network Bridge servers that have not yet been added.
- Select a Milestone Open Network Bridge server, and then click OK.
