Requirements for direct streaming
XProtect Mobile supports direct streaming in live mode.
You can use direct streaming to monitor more than 100 concurrent live video streams at Full HD 30 FPS. To do this, you must:
- Use cameras that support the H.264 codec or the H.265 codec.
- Allow direct streaming on your mobile device (see Buttons and settings overview).
Para obtener más información, consulte el manual de administrator para XProtect VMS.
