Specify rows per page
Select how many rows per page you want to see in grid fields in Milestone Customer Dashboard.
In the upper-right corner, select your login name and select User settings
On the User settings page, under Language and region, select the number of rows per page from the Rows per page dropdown
. You can choose between 10, 25, 50, or 100.
- Select Save
to apply the changes.
