Error descriptions (properties)
Depending on the XProtect VMS product that you are using, the table of error descriptions that you see in Milestone Customer Dashboard look slightly different. You can find the list of error descriptions generated by:
Management Client
Management Application
Milestone Customer Dashboard.
The list of error descriptions applies to the following products:
- XProtect Corporate
- XProtect Expert
- XProtect Professional+
- XProtect Express+
- Milestone Husky M500A
- Milestone Husky M550A
- Milestone Husky X series devices
- Milestone Husky IVO series devices
Error description |
Solution |
Error level |
Cannot retrieve images |
Make sure that the camera is properly connected to the network and is working. Verify that live video is available in the Management Client and XProtect Smart Client. |
Device |
Live FPS is lower than expected |
Check that the camera is running correctly and is not overloaded by other systems that also connect to it. Alternatively, check that the network connection to the camera has enough bandwidth and is stable. |
System |
Recording FPS is lower than expected |
System |
Used space is higher than expected |
The camera uses more disk space than expected. A full disk may be a result of:
Verify that the settings mentioned above are configured correctly. Also, verify that storage calculations are correct and that the retention time has been set correctly. Consider increasing available disk space. |
System |
Feed overflow (not all data recorded) |
The disk used for recordings cannot keep up with the number of data it is receiving. To solve this issue, do one or more of the following actions:
System |
Running out of disk space |
The storage with the media database is running out of disk space. Free up some disk space or move the media database to another disk that has more space available. Go to the Management Client and change the Recording paths for the devices to solve this issue. |
System |
Archive unavailable |
Check if the archive is unavailable due to a lost connection to a network drive or local drive. Then restore the connection. |
System |
Database storage unavailable |
Check if the database is unavailable due to a lost connection to a network drive or local drive. Then restore the connection. |
System |
Failover started |
Check why the original recording server failed and correct any issues that caused the failure. |
System |
CPU usage is high |
Check all processes running on the server and stop any unnecessary activity if you can. Alternatively, upgrade the server with a more powerful CPU. If the issue with CPU usage is taking place on a recording server, use the move hardware functionality to spread the load among recording servers. |
System |
Memory usage is high |
Check the server’s memory usage and see if you can stop any unnecessary activity or if you can add any additional memory to the server. Alternatively, use the move hardware function to spread the load among recording servers. |
System |
Service unavailable |
Check why the relevant service has become unavailable and correct any issues that prevent the service from running correctly. Restart the service. |
System |
Retention time |
More video is recorded than expected and the system predicts that it soon runs out of disk space and cannot record all video you have set the system up to record. A full disk may be a result of:
Verify that the settings mentioned above are configured correctly. Consider increasing the available disk space. |
System |
Archiving not finished |
Archiving has started before the previous archiving completed. This issue usually occurs when disks are too slow to finish archiving in time. If you are archiving to a network share or a Network-Attached Storage (NAS), the issue may also occur if the network is unstable or if it does not have enough bandwidth available. |
System |
Database disk full - auto archiving |
The disk used to store the database has become full. As a result, the system has started to move existing recordings to the next archive. A full disk may be a result of:
System |
Database disk full - deleting |
The disk used to store the database has become full. As a result, the system has started to delete recordings to free up some space for new recordings. A full disk may be a result of:
System |
Database full - auto archiving |
The disk used to store the database has become full according to your defined limits. As a result, the system is automatically moving existing recordings to the next archive. A full disk may be a result of:
System |
Database repair |
The system has started repairing the database because the database may have become corrupt. A database usually becomes corrupt if the recording server is shut down unexpectedly. |
System |
Automatic license activation failed |
The system could not automatically activate the license. Verify that the user name and password for the automatic license activation are correct and that the management server can access the URL for the Online Activation service. |
System |
Rule-generated alert |
Your system has been configured to send a message triggered from a rule. See the alarm description for more information. |
System |
No heartbeat from site |
Milestone Customer Dashboard is not receiving any heartbeats from your surveillance system. There could be one or more reasons for this situation:
System |
This list of error descriptions applies to the following products:
XProtect Essential
XProtect Express
XProtect Enterprise
Milestone Husky M20
Milestone Husky M30
Milestone Husky M50
Error description |
Solution |
Error level |
Failed to add to database - General |
Make sure that the media database disk is connected and accessible, and that the system has permission to write to the disk. |
Device |
Failed to add to database - Specific |
Device |
Cannot retrieve serial number |
Make sure that the camera is correctly connected to the network and working. Verify that live video is available in the Management Application and in XProtect Smart Client. |
Device |
Serial number is not correct |
A camera on the system has been replaced with another camera of the same type/model and with the same IP address. To fix this issue, remember to use the Replace Hardware wizard after replacing the camera. |
Device |
Maximum number of cameras allowed to run exceeded |
The system has tried to start more cameras than your license allows you to. Make sure that you have the right number of camera licenses to add the number of devices you want to use. |
System |
Camera failed to provide an image |
Make sure that the camera is properly connected to the network and is working. Verify that live video is available in the Management Application and in XProtect Smart Client. |
Device |
Image failure. Trying to reconnect |
Device |
Archiving failed to run |
Check the available disk space. If there is still available space on the disk, restart the server. |
System |
Database connection error |
Device |
The storage with the media database is running out of disk space. Free up some disk space or move the media database to another disk with more space available. Go to the Management Application and change the Recording paths for the devices to solve this issue. |
System |
Error deleting archive |
Make sure that the disk where your system saves its archives is connected and accessible, and that the system has full permission to the disk. |
System |
Cannot delete file |
One or more files in your media database or archives are locked and and you cannot delete the files. Make sure that the disks on which your media database and archives are located is connected and accessible and that the system has full permission to the disk. |
System |
Target path invalid |
System |
Failed to rename archive on same volume |
The disk you are trying to archive to is either disconnected or inaccessible. Make sure that the disk with archives is connected and accessible, and that the system has full permission to the disk. |
System |
Failed to copy archive to different volume |
The system cannot rename one or more archives. Make sure that the disk with archives is connected and accessible, and that the system has full permission to the disk. Also make sure that no files or folders in the archives are open, locked or in use by other processes than the surveillance system. |
System |
Error in processing an archive |
The system cannot copy one or more archives. Make sure that the disk with archives is connected and accessible, and that the system has full permission to the disk. Also make sure that no files or folders in the archives are open, locked or in use by other processes than the VMS. |
System |
Archive file move error(s) |
The system cannot process one or more archives. Make sure that the disk with archives is connected and accessible, and that the system has full permission to the disk. Also make sure that no files or folders in the archives are open, locked or in use by other processes than the VMS. |
System |
Recording server has restarted after a crash |
One or more files inside the media database are locked or inaccessible. Make sure that no files or folders inside the media database are open, locked or in use by other processes than the VMS. |
System |
Error description |
Solution |
Error level |
System |
