Select the date format that you want to appear in the Milestone Customer Dashboard interface and in the reports that you create.
In the upper right-hand corner, select your login name and select User settings
On the User settings page, under Language and region, select the desired date format in the Date format
dropdown list.
- Select Save
to apply the changes.
