FIPS-140-2 compatibility
This integration is compatible with operating systems that are running in FIPS mode, it is fully tested and supported in these environments. This integration is not officially FIPS-140-2 compliant. However, XProtect and OnGuard are individually both FIPS-140-2 compliant.
