FIPS-140-2 compatibility
Here is the FIPS-140-2 compatibility matrix between OnGuardXProtect Access Integration and Milestone XProtect. This integration is compatible with operating systems that are running in FIPS mode, it is fully tested and supported in these environments. This integration is not officially FIPS-140-2 compliant. However, XProtect and OnGuard are individually both FIPS-140-2 compliant.
OnGuard XProtect Access Integration Version
XP 2019 R1-R3
XP 2020 R1-R2
XP 2020 R3
XP 2021 R1 - R2
3.5 and below
U
U
U
U
3.6 and above
U
U
S
S
S: [Supported]
FIPS-140-2 is fully tested and supported on these versions
U: [Unsupported]
FIPS-140-2 is not supported on these versions
