Identify the host name of a node
You can check the current state of a computer from the failover web console.
  1. On a computer that has access to the failover cluster, open a browser and specify the URL of the failover web console: http://[computername.domainname]:9010 or https://[computername.domainname]:9453.
    The [computername.domainname] is the FQDN of the primary or the secondary computer
    On the primary and the secondary computer, double-click the icon of the XProtect Management Server Failover web console on your desktop.
  2. Select one of the nodes.
  3. Select the Information tab.
  4. In the Server information. area, you can see the host name of the computer.
