OnGuard and Oracle database compatibility
The MilestoneXProtect® OpenVideo integration with OnGuard is not compatible with an OnGuard system that uses an Oracle database. The only compatible and supported database technology for use with this integration is Microsoft SQL Server.
Using an Oracle database with OnGuard is an option that LenelS2 supports, however, the MilestoneXProtect OpenVideo integration does not support OnGuard systems that use Oracle databases.
