Logging and SQL databases
System log file
På den computer, hvor du har installeret Management Server-systemkomponenten, kan du finde systemlogfilen for XProtect Incident Manager. Placeringen for systemlogfilen er C:\ProgramData\Milestone\XProtect Incident Manager\Logs. Tjek logfilen, hvis du har brug for at fejlfinde systemfejl.
Logging of user activity in Management Client and XProtect Smart Client
XProtect Incident Manager stores detailed records of user activity in SQL databases.
When administrators in Management Client create, enable, and edit incident properties, these activities are written to the log server's SQL database SurveillanceLogServerV2.
When operators of XProtect Smart Client create and edit incident projects, the activities are written to XProtect Incident Manager's own SQL database named Surveillance_IM, to the log server's SQL database SurveillanceLogServerV2, or to both SQL databases.
Where the activities are logged depends on the specific activity.
Who and where Activity Activity logged in
Surveillance_IM SurveillanceLogServerV2
Administrators in Management Client
Define, edit, and delete all incident properties and settings related to XProtect Incident Manager.
No Yes
Operators in XProtect Smart Client Create and delete incident projects. Generate and print incident reports. Yes Yes
Open and export incident projects. Yes No
Edit incident projects. For example, apply or change incident types, statuses, categories, and data, and add comments or information about calls. Yes No
Create and remove sequences. Add and remove sequences to/from incident projects. Yes No
The Surveillance_IM database is located on the same SQL Server installation as the SQL database for the Management Server service. If you move the SQL database for the Management Server service, you must move the Surveillance_IM database to the same location. You can move and back up the Surveillance_IM database the same way as you do with other SQL databases.
See also Moving the management server and Managing the SQL Server and databases.
