Start or stop a node
On a computer that has access to the failover cluster, open a browser and specify the URL of the failover web console: http://`[computername.domainname]:9010 or https://[computername.domainname]:9453.
The [computername.domainname] is the FQDN of the primary or the secondary computer
On the primary and the secondary computer, double-click the icon for the XProtect Management Server Failover web console on your desktop.
On the left-hand side of the failover web console, select the button next to the node. Select Start or Stop to trigger action on the node. Wait until the console refreshes with the expected status.
You can run a global action on all nodes. Some local actions are only available on one node.
