Setting up a failover cluster
Make sure that XProtect Management Server Failover is installed on the primary and the secondary computer.
Verify that your system meets the requirement and schedule downtime. Your Management Server service will stop working during the configuration.
If you want to learn more about the prerequisites, see Before you configure .
The setup process consists of two parts:
