Remove existing failover cluster configuration
Remove your failover cluster configuration when:
The failover cluster configuration was not successful
Upgrading to a newer version of XProtect Management Server Failover
Changing the SQL database location
Updating the SQL Server version
Enabling or disabling encryption between the management server and the recording server
Changing the system configuration password
Troubleshooting an issue.
When you remove an existing failover cluster configuration, the XProtect Management Server Failover license, the SQL databases, and the server and user certificates are not removed.
Before you remove the failover cluster configuration, replace the virtual IP address with the address of a running management server on all clients and remote servers.
To remove the existing failover cluster configuration from the primary of the secondary computer:
In the notification area, right-click the Management Server Manager tray icon.
Select Configure Failover Management Server.
Select Remove existing configuration and then Continue. The wizard removes the failover management server configuration from the computer.
Select Close to exit the wizard.
Repeat the steps on the other computer that is part of the failover cluster.
