Logging
Logs are enabled for the MilestoneEvent Server plug-in and the CCure 9000 ACM Server, but they are set at the Info level by default when installed. The detail level of the logs can be increased for diagnostics purposes, but be aware that this change causes more information to be logged, thus consuming extra disk space and possibly slowing down operations on busy servers.
WARNING - Do not leave logs configured at increased detail levels. This level of detail should only be used for diagnostic purposes and returned to default afterward.
