Media service
There are two types of media services the driver supports. The Media 1 service (profile S) and Media 2 service (profile T). Some of the devices support both media services.
  • If the device supports only Media 1 service (ver10), only this will be in use.
  • If the device supports both media services (ver10 and ver20), Media 2 service will be in use by default. If the user wants to use Media 1 service, it can be selected in the drop-down menu followed by recording server restart. Otherwise, the driver will continue using Media 2 service.
  • If the device supports only Media 2 service (ver20), the driver will use this.
  • If the device does not support DeviceIO service, the Media 2 service will be unavailable.
Note: If the device supports both media services and it is added in the Management Client with a Device Pack which supports only Media 1 service, only Media 1 service will be available. With Device Pack upgrade (DP 9.5) which supports both services, still the Media 1 service will be in use. To switch the setting to Media 2 Service must be changed manually which requires a Recording Server restart afterwards.
