Sending notifications (explained)
You can enable XProtect Mobile to notify users when an event occurs, such as when an alarm triggers or something goes wrong with a device or server. Notifications are always delivered, regardless if the app is running or not. When XProtect Mobile is open on the mobile device, the app delivers the notification. System notifications are also delivered even when the app is not running. Users can specify the types of notifications they want to receive. For example, a user can choose to receive notifications for the following:
- All alarms
- Only alarms assigned to them
- Only alarms related to the system
These might be when a server goes offline or comes back online.
You can also use push notifications to notify users who don't have XProtect Mobile open. These are called push notifications. Push notifications are delivered to the mobile device and are a great way to keep users informed while they're on the go.
Using push notifications
To use push notifications, your system must have access to the Internet.
Push notifications use cloud services from Apple, Microsoft, and Google:
- Apple Push Notification service (APN)
- Microsoft Azure Notification Hub
- Google Cloud Messaging Push Notification service
There is a limit to the number of notifications that your system is allowed to send during a period of time. If your system exceeds the limit, it can send only one notification every 15 minutes during the next period. The notification contains a summary of the events that occurred during the 15 minutes. After the next period, the limitation is removed.
See also Requirements for notifications setup and Notifications tab.
Set up push notifications on XProtect Mobile server
To set up push notifications, follow these steps:
- In Management Client, select the mobile server, and then click the Notifications tab.
- To send notifications to all mobile devices that connect to the server, select the Notifications check box.
- To store information about the users and mobile devices that connect to the server, select the Maintain device registration check box.
The server sends notifications only to the mobile devices in this list. If you clear the Maintain device registration check box and save the change, the system clears the list. To receive push notifications again, users must reconnect their device.
Enable sending push notifications to specific or all mobile devices
To enable XProtect Mobile, notify users when an event occurs by sending push notifications to specific or all mobile devices:
- Do one of the following:
- For individual devices, select the Enabled check box for each mobile device listed in the Registered devices table
- For all mobile devices, select the Notifications check box
Stop sending push notifications to specific or all mobile devices
There are several ways to stop sending push notifications to specific or all mobile devices.
- For individual devices, clear the Enabled check box for each mobile device. The user can use another device to connect to the XProtect Mobile server
- For all devices, clear the Notifications check box
To temporarily stop for all devices, clear the Maintain device registration check box and then save your change. The system sends notifications again after users reconnect.
