Expand Rules and Events, right-click Analytics Events and select Add New.
In the Properties window, enter a name for the event in the Name field.
Enter a description text in the Description field if needed.
In the toolbar, click Save. You can test the validity of the event by clicking Test Event. You can continually correct errors indicated in the test and run the test as many times as you want and from anywhere in the process.
Edit an analytics event
Click an existing analytics event to view the Properties window, where you can edit relevant fields.
Edit analytics events settings
In the toolbar, go to the Tools > Options > Analytics Events tab to edit relevant settings.
Zorg dat uw reactie geen persoonlijke gegevens bevat, zoals uw naam, e-mailadres of telefoonnummer. Als u wel persoonlijke gegevens doorgeeft, dan verwerkt Milestone deze persoonlijke gegevens in overeenstemming met ons Privacybeleid. Uw persoonlijke gegevens worden zo snel mogelijk verwijderd in overeenstemming met ons Privacybeleid.
