Use picture-in-picture
If you see something that you want to investigate, but you don't want to stop observing the current situation, you can display live video using picture-in-picture (PiP) and play back video at the same time.
To turn on picture-in-picture (PiP):
  1. Switch from live mode to playback mode by tapping (Android) or (iOS).
  2. Depending on the operating system on your device:
    • Android - Tap
    • iOS - Tap
    Incoming audio is not available in PiP.
    To move the PiP window, tap and hold, and drag the PiP window to the preferred place on the screen.
Return to live video
To view the live video in full screen:
  • Double-tap the PiP window
  • Tap (Android) or (iOS)
