CCure 9000 versions
All updates and patches for CCure 9000 access control systems should not impact compatibility with theXProtect Access integration. If a minimum update or patch is documented, it will be listed here. If no minimum update or patch is listed, then all available updates and patches should be assumed to be compatible.
Version |
Minimum update / patch level |
Version information |
2.70 |
SP3_CU01 |
The Personalized Login feature will only work if CCure 9000 with SP3 CU1 or higher is installed. |
2.80 |
2.90 |
