ACM Server: XProtect ACM MIP Plugin
In most scenarios, the XProtectManagement Server host server is where this component is installed. However, it is technically required to install this final component on the server that hosts the XProtectEvent Server. Go to the XProtectEvent Server host and locate the required .msi file. The required file is named:
  • Milestone.ACMServer.MipPlugin.msi
Double-click the installation file. Once the wizard detects the XProtectEvent Server it will continue. Click Next to continue. At the Destination Folder step the default installation directory is provided. This is the default location:
  • C:\Program Files\Milestone ACM Server MIP Plugin\
Change the directory location if required, or click Next to continue. Complete the XProtectEvent Server MIP Plugin installation wizard.
