Troubleshooting Milestone XProtect VMS video driver
Video Driver logs are defined in the following file:
ACVS.Enterprise.Server.Configuration.exe.config
The file is located here:
C: Program Files (x86) \Tyco\CrossFire
Alternatively, at the following location in a system that has been upgraded:
C: Program Files (x86)\Software House\SWHSystem\CrossFire
The config file contains this text:
<appSettings>
<add key = “TraceViewer.Enable” value=”true”/>
</appSettings>
The value parameter can be set to true or false to enable or disable logging.
Open the Server Configuration Application in CCure 9000. Select the Diagnostics tab. Click on Connect. Several modules appear. Select MileTraceSwitch and set the trace value.
Red for Error
Yellow for Warning
Purple for Info
Green for Verbose
