Export the video
To export video evidence:
  1. Add the video sequences that you want to export to the Exports tab > Export list.
  2. Create the export.
Add video sequences to the Export list
You can add video sequences to the Export list on the:
Create the export
The Create export window. Choose a name and export destinaton, and optionally, add comments to the XProtect format of the export.
  1. Click Export. The Create export window opens.
  2. Enter a name for the export file.
  3. Specify the export destination.
  4. Click Create export.
To access the export after it is created:
The Export details window. The export location is a hyperlink. When you click the hyperlink, the folder that contains the export files opens.
  1. Click Export details in the upper-right corner.
  2. Click the Export location link.
Export formats
Some export formats may be unavailable to you because of limited user rights. In that case, please contact your system administrator.
Format
Description
XProtect format
Export video from multiple cameras at the same time, and with digital zoom capability.
This option requires the following:
  • You must use XProtect Smart Client – Player to view the video. It is included in the export and does not require any configuration
  • You must be running a Windows operating system on your computer to view the video
Media player format
Export video from multiple cameras as separate video clips that you can view by using a standard media player. For example, Windows Media Player.
This option allows you to select one of these formats:
  • AVI format - with or without audio
  • MKV format - with or without audio
Still images
Export still images.
