XProtect Incident Manager (usage)
When the XProtect Incident Manager add-on is installed and configured, and the administrators of the VMS have given you the needed permissions, you can document and manage incidents in XProtect Smart Client and save all information in incidents projects.
On the Incidents tab, you can view and update your incident projects and manage your incidents. You typically add sequences and various textual information to your incident projects to document and prove what happened when an incident occurred.
- Filter the list of incident projects to find the relevant incident project quickly
- See the status, type, start and end time, and description of the different incident projects
- Keep your incident projects updated with the latest actions and other development in the management of the incidents
- Generate reports and export the incident projects' sequences to share the evidence internally or externally
