Management Server
Adjust the token time-out
XProtect VMS uses session tokens when it logs in to the management server using SSL (basic users) or NTLM (Windows users) protocols. A token is retrieved from the management server and used on the secondary servers, for example the recording server and sometimes also the event server. This is to avoid that NTLM and AD lookup is performed on every server component.
By default, a token is valid for 240 minutes. You can adjust this down to 1 minute intervals. This value can also be adjusted over time. Short intervals increase security, however, the system generates additional communication when it renews the token.
The best interval to use depends on the deployment. This communication increases the system load and can impact performance.
Learn more
The following control(s) provide additional guidance:
- NIST SP 800-53 IA-5 Authenticator Management
Enable only the ports used by the management server
Milestone recommends that you enable only the ports used by the management server, and that you block all other ports, including the default Windows ports. This guidance is consistent for the server components of XProtect VMS.
The management server ports used in XProtect VMS are: 80, 443, 1433, 7475, 8080, 8990, 9000, 12345.
The ports used depend on the deployment. If in doubt, contact Milestone Support.
Learn more
- NIST SP 800-53 AC-2 Account Management
- NIST SP 800-53 SC-7 Boundary Protection
Disable non-secure protocols
When a basic user logs in to the management server through IIS, the Management Client will use any protocol available.Milestone recommends that you always implement the latest version of the Transport Layer Security (TLS, currently 1.2) (https://datatracker.ietf.org/wg/tls/charter/), and disable all improper cipher suites and obsolete versions of TLS/SSL protocols. Perform actions to block non-secure protocols at the OS level. This prevents the Management Client from using protocols that are not secure. The OS determines the protocol to use.
The protocols used depend on the deployment. If in doubt, contact Milestone Support.
Learn more
- NIST 800-53 AC-17 Remote Access (Disable Unused Protocols)
- NIST 800-53 CM-6 Configuration Settings
- NIST 800-53 CM-7 Least Functionality
Disable legacy remoting channel
Communication between the recording servers and the management server has become more secure with the solution implemented in 2019 R2. If you upgrade from a previous XProtect VMS release, the management server still starts the legacy 3rd party technology to be able to communicate with recording servers on older releases.
When all recording servers in your system are upgraded to version 2019 R2 or later, you can configure the management server to not start the legacy remoting channel, to make your system less vulnerable, Milestone recommends that you set UseRemoting to False in the management server configuration file.
Learn more
Manage IIS header information
Disable IIS header information
For security purposes, Milestone recommends that you disable the X-Powered-By HTTP and X-AspNet-Version headers.
The HTTP header X-Powered-By reveals the version of IIS being used on the server. Disable this header by doing the following:
- Open the IIS Manager.
- Select the Default website.
- Select HTTP Response Headers.
- Select the X-Powered-By HTTP header and select Remove.
The HTTP header X-AspNet-Version reveals the version of ASP.NET being used by the Management Server application pool. Disable this header by doing the following:
- Open the web.config file located in %windir%\Microsoft.NET\Framework\v4.0.30319\CONFIG.
- After the <system.web> tag, add this: <httpRuntime enableVersionHeader="false" />
- Save the file.
The SERVER header variable should not be removed, because it will cause functionality within Management Server to break.
Set X-Frame Options
For security purposes, Milestone recommends that you set the X-Frame-Options to deny.
When you set the HTTP header X-Frame-Options to deny, this disables the loading of the page in a frame, regardless of what site is trying to gain access.
Change this header by doing the following:
- Select the Default website > Installation.
- Right-click and select Add... from the menu.
- In the Name field write X-Frame-Options, and in the Value field write deny.
Disable IIS HTTP TRACE / TRACK verbs
For security purposes, Milestone recommends that you disable the HTTP TRACE verb in your IIS installation. Disable the HTTP TRACE verb by doing the following:
- Open the IIS manager.
- Double-click Request filtering.
If Request filtering is not available, install it by following the instructions here: https://docs.microsoft.com/en-us/iis/configuration/system.webserver/security/requestfiltering/
- Select the HTTP Verbs tab.
- Select Deny Verb from the Actions menu.
- Type TRACE and click OK.
- Type TRACK and click OK.
- Select Deny Verb from the Options menu.
- Type OPTIONS and click OK.
Disable the IIS Default Page
For security purposes, Milestone recommends that you disable the IIS Default Page. By doing this, you remove information that could be used to discover what technologies are used in your installation, and you align with IIS Best Practices as defined by Microsoft. Disable the default page by doing the following:
- Double-click Default Document.
- Select Disable in the Actions menu.
