Enable event server encryption
You can encrypt the two-way connection between the event server and the components that communicate with the event server
When you configure encryption for a server group, it must either be enabled with a certificate belonging to the same CA certificate or, if the encryption is disabled, then it must be disabled on all computers in the server group.
- A server authentication certificate is trusted on the computer that hosts the event server
First, enable encryption on the event server.
Steps:
On a computer with an event server installed, open the Server Configurator from:
- The Windows Start menu
or
- The Event Server by right-clicking the Event Server icon on the computer task bar
In the Server Configurator, under Event server and add-ons, turn on Encryption.
Click Select certificate to open a list with unique subject names of certificates that have a private key and that are installed on the local computer in the Windows Certificate Store.
- Select a certificate to encrypt communication between the event server and related add-ons.
- Click Apply.
Select Details to view Windows Certificate Store information about the selected certificate.
To complete the enabling of encryption, the next step is to update the encryption settings on each related add-on
